First Taildragger-4 * 60
The 4*60 is fairly gentle about ground handling. Advance the throttle smoothly and it should behave just fine. A tiny bit of up elevator until it gains somne speed, then let the tail rise and the plane should lift off without you holding up elevator. (almost as easy to fly as your trainer.)
If it seems to have problems with wanting to spin in circles as it builds speed, gently bend the wheels to point inward JUST A LITTLE.
