RCU Forums - View Single Post - Seal hinges on Somthin Extra?
Old 01-31-2004 | 07:48 AM
SALMONBUG's Avatar
SALMONBUG
Default RE: Seal hinges on Somthin Extra?
ORIGINAL: jerryj39
salmonbug, How do you seal the hinge line with clear tape? How do you get the tape to be on the same hinge line as the hinges?
my english is not very good, but I will try to explain
buy clear packin tape aproximatly one inche wide, not that you can also find a tape especialy designed for that in your LHS
-cover and hinge your surfaces permantly
-deflect the surface to the maximum and find a way to block it in that position
-apply the tape with half sticking to the control surface and the other half sticking on the fix surface, be sure that your tape also stick in the edge between the surfaces, all the lenght of the flight control
for planes like a somethin extra I suggest to seal only on one side to keep the things easy
this is a frustrating job, but what I like in that method is that if you miss it, simply remove the tape and try again.......
