ORIGINAL: Airo-RCU
Jim again; There were a few posts I read that said, that the WH 540T had a light pull to the left on vertical with a DA-50. According to that when mounting a DA- 50 you need to put in more right thrust. So the reason I asked on last post was to get it straight from you. I would appreciate some info on this. Thumbs up on your new EDGE.
I have seen those posts but have not had the same experience myself, my testing has the plane pretty much neutral with respect to thrust angle. IF it's tail heavy it does tend to wander when pulling vertical, but if balanced properly I have not seen any need to change thrust angle (if I had I would have done it). YMMV
TF
