RE: Need Help with Ailerons Servo. Please Help!!
That plane WILL require elevon mixing. A basic 4-channel radio will not do it, though a Hitec Flash4 or Flash5 will.
One servo plugs into the elevator channel, the other plugs into the aileron channel. When the mixing is activated, the two servos work together to provide both control movements.
A simple y-harness will NOT work for this plane.
