RE: hyper 7 tires
yeah super glue works but you can also use the tire glue found at any lhs. The factory default breakin settings are really rich and you will need to lean it out(alot in some cases). I recommend buying a temp gun so you can check the teperatures before you start leaning it. But like you said you are nearly done so you might not want to think about leaning it a lot. Just enough to get the engine running around 220+
