RCU Forums - View Single Post - fun piccolo tail motor problem
Old 02-01-2004 | 09:06 PM
VinceHerman's Avatar
VinceHerman
Default RE: fun piccolo tail motor problem
Here are a few - good - links that should help get you going.
Possible cause is a slipping pinion on the tail motor. A dot of CA on the end of the shaft may help (don't let it run into the motor). Do you have the gear mesh set properly?
Do read the pages from the links above. They do have a world of good information in them.
Good luck. Let us know how you do.
