RE: OMP YAK54 NOW COVERING!
Leave the sheeting over the channel. You will fish the servo wires through the channel later.
I glued my stab halves together on a flat board with the wire installed. After I built the fuselage I cut the slot for the stab all the way to the rear of the fuse. After I slid the stab in, I glued the end piece of the fuse back in.
