RE: u-can-do 60
Greetings Roger, negative on the Giles, can you believe everytime I get set to go the weather has beaten me to the field!!! I guess its fate!! Once the weather gets above 40 degrees and there is no snow im gonna run out there and put her up! Pics will follow of course!
As far as the ucando Roger/Joe how much right thrust did you put in?
I have to agree with Roger on the engine mount situation. I got a Jtec mount with pre-drilled holes for the mounting screws. Makes life anlot easier doing an engine install with it.
Joe your servo in the belly mod is outstanding and I am jealous. Setup looks clean and straightforward but I have to ask about the hole you cut out to get the servo in. How was that accomplished to be able to secure it place without sacrificing structural integrity?
