RE: OMP YAK54 NOW COVERING!
The instructions say to cut out the foam and sheeting in FRONT of the rear stabilizer. Thats just crazy I cut out behind the stabd and just glued that tiny piece back in. Its gonna be strong anyhow when i glue the fin on back of the fuse. You can slide the elevator in then slide the stab in but you gots no room to install hinges.
Throw: I dont know who thought of the idea of glueing tri stock on the the back and front of the control surfaces but its brilliant, easy to install and allows for 90 degrees throw! I installed robart 1/8" hinges in all surfaces, just got a bit of fuse trim to install tonite and it will all be covered. Getting close now!
I think your saito 100 with small digi's will be a great setup
