RE: Engine Problems
i suggest you cut a hatch because you may have to take the tank out several more times to fix the problem. simply relpace all the lllines. you will never be able to find a pinhole leak unless you do a pressure test. jsut replace them all. but could you tell me whether you see bubbles coming into the needle or not?
