RCU Forums - View Single Post - Aluminum spinner slightly bent ? Is this normal ?
Old 02-02-2004 | 11:22 PM
DBCherry
Default RE: Aluminum spinner slightly bent ? Is this normal ?
The spinner should have had two "cut outs" in it that are meant for the prop blades to pass through. Sometimes the cut outs need to be enlarged to fit the prop, because they are not large enough and the spinner sits on the prop blades.
The spinner should NOT touch the blades of the prop.
Dennis-
