RCU Forums - View Single Post - Built up wing question!
Old 02-03-2004 | 02:21 PM
RCHYFLYER
Default Built up wing question!
I'm building the Top Flite Cessna and I'm fiberglassing it. I ran into a resin pump problem that gave me a uncurable mix on one panel of my wing. I pulled the sheeting off that panel and I am sheeting it over again. Here is my question, when sheeting originally I had to do the bottom of the wing first,then put jigs on the wing tips and center section, weigh it down which put in washout at the tips and sheet the top panels. Will removing the bottom panel sheeting cause the washout to relax? With the wing on a flat surface I took some measurements and I don't see any difference from the unsheeted side to the sheeted side. What do you think? oh I forgot to mention that all of the wing except the panel in question has one coat of resin and cloth on it, so maybe that will help hold the washout.
