RCU Forums - View Single Post - Can incorrect wing incidence be corrected with ail, elev, or eng thrust adjustments?
Old 05-31-2002 | 02:07 PM
SMALLFLY-'s Avatar
SMALLFLY-
My Feedback: (19)
Default Can incorrect wing incidence be corrected with ail, elev, or eng thrust adjustments?
Im no expert but I would try several degrees of down thrust. The wing will have several degrees of positive incidence making it want to lift all the time and several degrees of down thrust will help counter this. It also turns in to up thrust when inverted so it will help inverted flight as well
