RCU Forums - View Single Post - Can incorrect wing incidence be corrected with ail, elev, or eng thrust adjustments?
Old 06-04-2002 | 11:57 PM
AQ500's Avatar
AQ500
Default Can incorrect wing incidence be corrected with ail, elev, or eng thrust adjustments?
The dazzler is designed for zero incidence.....You have 1.2 degrees positive incidence. You will notice a difference when inverted. It will still fly fine. Fix it if you want. You might like how it flies better with zero incidence. You will have to apply more down elevator to fly inverted with the positive incidence.
My $.02
