Servo post extention
I'm building a pan/tilt for a camera on my plane and can use your help.
For the pan/tilt you need 2 servos. In order to minimize the exterior drag I have one servo mounted inside the plane for horizontal pan and other servo outside the fuse for vertical tilt. The servo mounted inside the plane is mounted so that the post is sticking through a hole in the fuse (yes the servo is mounted upside-down). The other servo (the vertical tilt servo) outside would then be mounted to the horn of the first servo.
So the problem is that the servo stem/post of the one inside(sticking out) is too short to fully extend outside the fuse, so that I can attach a horn onto it and then the second servo, without it rubbing on the outside of the fuse. Is there a place I can buy a device that will basically extend the length of the post so that it is a little longer ?
I hope this is clear enough to understand.
e-up !
