Missing step in piper cub ARF plans?
I'm building the Cub .40 ARF, and I think they might have left out a small step. The two wing halves have strings that run through them so you can pull the servo cords through the wing easily. They end up coming out of holes on the ends of the wing where they will be glued together. There are 2 identical holes in the sheeting on the underside of the wings, (they are covered), lined up with the exit holes on the wing ends So i cut the covering on the other holes and pulled the strings through the bottom holes so they arent in the way for gluing, and so you can access the strings later. It is pretty much common sense, but it doesnt mention it at all in the plans, or even show any pictures of it done, or even of the underside of the wings. It doesnt say anywhere where to route the wires either (again common sense, but should be at least mentioned...)
Tell me what you guys think... -Dan
