RE: HANGAR 9 CUB 80"
Some times you can see the warp by looking at it from the leading edge while your buddy holds it up at eye level. If it took full trim to level it, the warp should be visible. If it is warped and the light is right, one side will look flat and you will be able to see part of the top or bottom surface on the other side.
