RCU Forums - View Single Post - Engine Problems
Old 02-04-2004 | 01:12 AM
  #37
Spaceclam's Avatar
Spaceclam
Default RE: RE: Engine Problems
well, some bubbles may be expected, especially if it is low on fuel. there are bubbles before the line and you have replaced everything so it is probably vibration. a quick question. did you mount the tank cap to the firewall with silicone glue like they tell you to? that will cause your tank to foam and would explain most of your problems.
