RE: Sig Mayhem 3D ARF
Brittgo 6
Easy! Take a small plastic tubing like an old "Goldenrod" or antenna sleave available at LHS for about a buck-then thread it in from the exit hole in the back. Just a little wiggleing will do the trick. You can then push the cable through the tube, then pull out the tube.
Worked for me on several models.
Good luck.
Robin
