RCU Forums - View Single Post - Antenna Routing
Old 02-04-2004 | 03:18 PM
2mistakeshigh
Default Antenna Routing
I am building a SIG Spacewalker II 40 size ARF. My instruction manual says to route the antenna through the fuselage and attach it to the Vertical Stab. I was wondering if there would be any problems in routing the antenna through the length of the fuse and exiting it out the rear of the aircraft in lieu of how they tell you to route it in the instruction manual.
I have a trainer that has the same type of antenna installation and all seems to work fine.
Any suggestions would be appreciated.
