RE: JEH Ignition
Guys I just ran up my Q35 equipped with JEHI system triggered with points and I'm very pleased.Not only Did I loose at least a pound in dead weight, (I was able to remove the 5 oz. tailweight) but also saw a nicer running engine.One prob. though the run time on 500mah. nicad 4.8v. is'nt long enough I suspect it's because the dwell is way to long>The timing led lite stays on for almost 260deg. with the points system excessively draining battery. Also top Rpm's are down from 6900 to 6400 w/18/10 MA classic but i think thats just timing. I set points at 17 as thats what the author of Quadra bible recomends but that may change with electronic ign.[&:]
