RE: 4*60 throttle cable help!
sounds like you kinked the cable or the tube... maybe the cable is fraying the end.. if its fraying the end, twist opposite what would screw the cable in.
If its kinked tube you need a new tube. (if the tube is already installed) Cut it off at the kink if its not installed and see if you have enough tube.
If its kinked cable... you do similar to above... depends where the kink is.
