RE: RE: Sig Mayhem 3D ARF
Received mine today very nice looking arf. Totally impressed with the hardware pkg will use most of it. I am going with a Saito 120 inverted with the wieght of this plane should be plenty of power. Fut 9102's in the airelons but not quite sure on the rudder and elevator. Have heard a lot about the Fut 3305's plenty of torque but I hear they are a little on the slow side. Have run into a slight problem this evening putting the wing panels together just wondering if anyone else has seen this problem? I am not getting a flush fit at the trailing edge og the wing root. I have tried it with and without the dihedral brace installed so I am inclined to think it is in the wing panel itself. Any fix to this or should I haul it back to the local hobby shop I am hesitant as it is 45 miles away. Will appreciate any input as to build mods or servo selection. Can't wait to hear some flight reports as I am probably a couple weeks away.
