RE: Help the new guy...
Do a search on this plane you will find oodles of info on it. If there are any areas to be addressed I'm sure you can find them. I have never seen one or used one. So I will not advise on what to modify other than epoxieing some triangle stock to the rear of the firewall and be sure of the stab and fin glue joints as well as the wing joint.
To dress up the plane you can buy Monocote trim sheets in a pile of colours. Just buy the ones you want and cut out whatever exites you the most. An stick the trim on whereever you feel happy with. I like a bright color on the top and bottom of the wing and stab tips. As well as on the top of the rudder and fin. I also like to put a thin strip along the leading edge to aid visibility. Yellow,orang and red are the 3 best colours to add for visibility. It is nice to be able to see orientation easily. Good luck with your new plane and have fun.
Mark Shuman
