RCU Forums - View Single Post - balancing props
Old 02-04-2004 | 10:34 PM
kingkiley
Default balancing props
Ok,
I had to install a new prop on my Alpha Trainer.
My question is should I balance the prop or just leave it the way I bought it?
If I should balance the prop, how do I go about doing this?
Also, the engine mounting bolts have worked themselves loose a little bit. I don't want to take out the whole engine, is there some kind of tool that I can make/buy that would turn in those bolts with out taking out the whole engine?
One last thing, I know that this has been asked alot, but can someone please tell me how to set the low/high idle needle settings to get the engine to run? I can't even get the engiine to cought!
king K
