RCU Forums - View Single Post - Official Whiplash Tech Site
Old 06-06-2002 | 12:36 AM
BAGOSTIX's Avatar
BAGOSTIX
My Feedback: (178)
Default whiplash fuel tanks
There are bladder type fuel tanks that will fit the whiplash available.
We will soon have an accessory page that will have fuel bladders, whip antenaes, tuned pipe brackets, and many more items for you guys that want to customize your whiplash.
We have found that the tank that comes with the kit has a small blister on top that hampers a flush fit on the rear exhaust pipe when using a Jett 50..
A bladder type tank will eliminate this problem and will also help with those pesky vibration bubbles..
if using the tank provided, if you use foam on the bottom of the tank and surround it with silicone, it will help to eliminate bubbling problems and the silicone will hold the tank firmly in place and reduce vibrations too.
