Did you follow the procedure in this link.
http://www.acehobby.com/manuals/heli...rotorblade.pdf
This is even more important with a 60 because the blades are bigger and will put more stress on the wood toward the bolt. This is usually something you normally don't spot after going over a machine, you usually have to ask them if they did it if you remember.
