RE: INSTALL PROBLEM
Hi: When you first start to load disk does it tell you the version it is? And what operating system are you trying to put it on? If it does'nt tell you the version on load put the disk in and check under Properties. I sent you a email--did you get it? With the above information maybe we can get it installed.
