RCU Forums - View Single Post - servo alignment assist needed
Old 02-05-2004 | 01:48 PM
mikenlapaz
Default RE: servo alignment assist needed
Use the ball link on the servo...
Is that just a drill out of holes(s) in s arm and bolting on with 2-56 bolt? Just have never seen it done, but my opportunities are limited.
horn not being directly above the hinge line
Attachment will be directly above hinge, it was the angle being off 90 degrees (6-8) that was the concern.
Location is outboard due to making the rudder cutout larger due to a folding problem and material availability restraint. The plans http://www.spadtothebone.com/SPAD/ultraspadstick/ use 2 std servos for the elevator.
I really appreciate the time that you fellas take to share your knowledge even if it is going in a SPAD. If I don't learn here, I won't learn locally.(Poco Espanol para mi!)
