RE: 4*60 throttle cable help!
Soldering Irons come in differant heat ranges, depending on there intended purpose. If you have one desighned for fine eletronic work, Usualy with a fine point, It wont put out much heat. also dident you say earler that you receved a shock from it? If so for you own saftey replace it!
