RCU Forums - View Single Post - servo alignment assist needed
Old 02-05-2004 | 08:27 PM
wrongwaywayne's Avatar
wrongwaywayne
Default RE: servo alignment assist needed
What are you talking about? Of course it is a good idea to use your computer transmitter to make travel volume adjustments - within reason. It is a SPAD afterall. Use some common sense when using your radio to adjust ATV, you can't fix everything. Don't over do it. Add too much and you'll reduce the power of the servo.
Sometimes the only way to make servos react equally in both directions is to use a computer.
