RE: RE: 3DX!
Well, as it turns out, I donm't have everything here tonight. If the charger doesn't show tommorrow, I will see if the missing LM317TB can be had locally. or the next step up for up to 3 amps as 1.5 would be ideal and not tax that reg. I had every intention of clearly nmarking the homebuilt as "FOR 3 CELL LIPOS ONLY" on all sides of the enclosure.
I wonder if I could use a 12 volt 400 ma wall wart while monitoring voltage temperature and amperage just to get the cells above the 3.1 V per cell to avoid dammage. Conect it for say 10 - 15 min max while monitoring.
