RCU Forums - View Single Post - Pro spinners
Thread: Pro spinners
Old 02-06-2004 | 09:36 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Pro spinners
The back plate comes with the spinner.
And yes, most times you need to enlarge the prop holes. Spinners can go on many different size engines, so the MFGers usually cut the holes to accommodate the smallest prop sizes. If you're using something larger, you need to file the hole bigger (A dremel is the tool of choice for this job)
