ORIGINAL: tiggerinva
However, with a 4 stroke engine, a tach is more or less a necessity.
Trig, you must be a Tach salesman.
I have broken in more engines that I care to think about, and I used a tach for the first time last summer. The only reason I bought/used it, is that I was doing an engine review, and I wanted a picture showing the tach reading. And that is still the only thing I would ever need to use one for.
What difference does it make what RPM you're turning? Use a break in prop, and set it a little on the rich side. I have broken in every engine I own this way, and every one runs beautifully.
