RCU Forums - View Single Post - Inverted Hovering. It has been done now!
Old 02-06-2004 | 06:08 PM
  #74
Simon Jones
Default RE: RE: RE: Inverted Hovering. It has been done now!
Woooow chill guys.
Hobby - should be fun.
Whether this is or isn't hovering, at least it's sparked some ideas.
Jon I like the thought of reversing the thrust, intersting in a waterfall, blender entry, etc.
Now I'm no electric wizz, and thse small foam 3d models just aren't available over here but am I righ in thinking that to reverse the rotation of a brushless you have to swap two of the motor connections?
I guess these motors on the small models are only sucking sub 10Amps? If so what about using a servo to drive something similar to a small mechanical speed controler that swaps the motor wires? A double pole, double throw switch basically. This would have to be switched or mixed in on a different chanel but I guess could beachieved at under 25grams, possibly closer to 15g with a 4.6g servo, a couple of bits of cuircuit board and a nut and bolt.
I guess from this side of he pond I'll have to watch this space.
Good luck with the quest.
sj.
