RE: First Attempt at CA hinges??
Just be careful putting the drips of CA on the hinge-line and it will wick right into the hinge.
2 drops per hinge one side... then 2 drops per hinge the other... then do the first side again... then the second side again. It'll soak up the CA and be nice and firm. (you can put up to 6 drops per side of each hinge if you want...)
The main cause of CA running off is putting too much in one spot at a time.
