RCU Forums - View Single Post - 6 months later
Old 02-07-2004 | 06:05 PM
DBCherry
Default RE: 6 months later
I like the pattern you used for covering it, and the front hatch. that will make getting to the tank a lot easier, and you'll probably have to (I usually do).
I agree with Cobra about the switch. You don't want to have to pull the wing off between flights. If you mount it on the left side of the fuselage, it will also keep most of the fuel/oil residue out of it.
What are you going to do with the rest of your winter, start on your second plane?
Good luck and have fun!
Dennis-
