RCU Forums - View Single Post - IMAC Basic Sequence
Old 02-07-2004 | 09:27 PM
Ryan Nau's Avatar
Ryan Nau
My Feedback: (54)
Default IMAC Basic Sequence
I'm going to be flying IMAC this year instead of funfly competition. I've flown the basic pattern a few times, will practice it a lot when it warms up. I have some questions about how the manuevers are judged.
2nd Manuever is the hammer head in the pattern. When you pull up, do the stall turn part of it and go down. Do you pull out of the hammerhead at the same attitude you started it??? or do you go down futher on the downline?
Same thing with the Humpty bump. Do you pull out at the same attitude you started it at? Where at in the manuever are you supposed to do your half vertical down roll at? on the diagram on the imac site is looks like you do your half roll past the starting attitude??
For the 1/2 cuban 8's, you do you roll in the middle of the 45 line right, or two seconds starting the 45 line?
Spin, you have to stall it to go into the spin and have it vertical down.
Is there anything that tells you what the judges look for mistakes wise and how to do your areobatics correctly?
thanks
ryan
