RCU Forums - View Single Post - HELP: setting up kill switch
Old 02-08-2004 | 02:53 AM
nitrogary
Default HELP: setting up kill switch
Hi Everyone,
Sorry about the blank i just posted, couldnt find the cusrsor.
My question: Im setting up a3W 100ib2 with the 3W older ignition, it has a battery lead and a 3 pin connector to the sensor on the crankshaft, I also bought the greatplanes ignition kill switch, can i use this to have a functional kill switch and how do you wire it up or is there a pre-made unit that i should be using...basically i dont know how to tap into the module if possible..im looking for the most reliable setup possible...i didnt see anyhting on aircraft international's site or Cactus aviation either
