RE: HELP: setting up kill switch
I would not suggest utilizing Great Planes ignition kill switch. If I recall this is a mechanical micro switch with some leads attacthed to it. It was designed for weedy engines and such with magnetos I believe. That said if you could use the switch to turn the battery on and off. The problem I see is the mechanical action of the switch, together with the possibliltiy of generating EMI...
