RE: need help identifying problem
that click is when the diff is slipping. i also own a xxxnt and its a good idea to rebuild the diff every 1-2 gallons. u can fix right away by putting a small hex wrench through the bach right drivecup then turn the other wheel forward abotu an 1/8 of a turn that should tighten up the diff. also look in ur manuel it explains it a little better in there.
