RCU Forums - View Single Post - just a ?
Thread: just a ?
Old 02-09-2004 | 09:33 AM
Ben Lanterman's Avatar
Ben Lanterman
Default RE: just a ?
The increased length will give more rudder power but unless there is lifting area on the fuselage up front it won't help much. Notice most modern pattern airplanes have a lot of area forward of the trailing edge of the wing. This gives them lift in knife edge. Adding fuselage height with a light foam block (streamlined of course) would be a quick test of whether or not the extra fuselage height would work.
