RCU Forums - View Single Post - Jet radio modulation
Old 02-09-2004 | 09:49 AM
HarryC
Default RE: Jet radio modulation
I would certainly not suggest that you switch from your current PCM to a PPM failsafe. However you should be aware that the benefits you believe that you get from PCM are also equally available on PPM though it is only from a limited number of brands at the moment, as this could affect a future purchasing decision. This ties in with another thread that is current at the moment, jet fliers want lots of channels, there are two brands that give you four different 12 channel radios. Both brands give 12 channels only in PPM, but only one of them offers that PPM with the full glitch protection and failsafe that PCM offers. If you did not know any better then you would assume that both brands do not have failsafe if you believed that failsafe is exclusively a PCM behaviour.
H
