RE: Old Engine Question !!!!!!
Very often just heating the carb will free it up. If you have a heat gun, just heat it up and try to move it while it is hot. If it moves, then use some fuel or after run oil on it to keep it free. If not take the above advice and soak it in kerosene or alcohol over night and try again.
