Sophia sputtering
Hi,
If you think its the fuel supply then you could put in a damper
as an experiment, tee in a length of tube about 18" between the pump and the turbine, run in fuel until it is about 5-6" into
this tube and then pinch the end off, the air in the tube acts
a bit like a damper and absorbs the worst of the uneven pulses.
Mike
