RE: Drop engine Stand
just bench tested. I need to make a shaft with left hand threads, or find a better way to lock the prop nut and starter cone. It looks as if the belt is going to hold up for a while, but I will be trying belts made from different material.
Thinking about drilling and tapping the nuts in place. The prop can be drilled and pinned, because I have a nut on both sides of the prop. Any ideas??
