RCU Forums - View Single Post - engine bogging on high speed
Old 06-04-2002 | 01:12 PM
Jazzy
Default engine bogging on high speed
On some engines, but not all, the idle mxture screw/needle will greatly affect the high-end mixture.
I've gone through this senario:
Top end perfect but bottom too rich-leaned low end <1/8 turn.
Now top end too lean but bottom just right.
Opened top end to 'just right' setting.
Now bottom too rich again.
Yadda, yadda, yadda.
Check all O-rings and take whatever steps necessary to seal them: i.e. slightly larger O-rings, fuel tubing, etc.
Also, make sure the carb body seals well against the crankcase. Sometimes a little blue RTV works wonders.
It may just take some tinkering to find that sweet spot.
Hotter plug? Cooler plug?...
