RCU Forums - View Single Post - SAITO .91 HELP!
Old 02-10-2004 | 01:58 AM
Flyboy Shady
Default RE: SAITO .91 HELP!
Keith,
Put the engine back together again right away! Your warranty goes out the window if you fiddle with it.
The most likely cause for your problems is that you have adjusted your main and the low speed needle out of range. Try the Saitos recommended starting settings and start all over.
Best regards,
/Fredrik
