RE: SAITO .91 HELP!
pohl, when observing the crankshaft from the back with the backplate removed the intake valve should close on the compression stroke when the crankpin is about 110 degrees BTDC and on the exhaust stroke both valves will be open from approx 20 degrees BTDC to about 20 degrees ATDC.
