RE: SAITO .91 HELP!
Keith:
A quick word of warning. All the gaskets in a Saito engine can be made with RTV EXCEPT the gasket for the cam shaft housing. This gasket sets the mesh for the timing gears, it has to have a thickness of about 0.005" when compressed.
If your original gasket is damaged and you do not have a new one, you can cut one from a sheet of notepaper, and use a thin coating of RTV on each side to seal it.
Bill.
